Activity Forums Adobe Encore DVD “Edit Quality Presets” goes back to default
  • “Edit Quality Presets” goes back to default
    Posted by Roy Messinger on July 7, 2009 at 11:51 am
    Hi, I am going to make a DVD with some standard mini dv clips.
    After opening a project with DVD authoring mode, I open the File – “Edit Quality Presets” and on the right side of “Export Settings”, I choose “Format” – Mpeg2 DVD with default “Preset” then hit OK.
    When I come back to this “Export Settings” window again, all the settings return to the defualt.
    Am I missing something ?
    Thanks in advance.
    Roy
    Jeff Bellune replied 17 years, 2 months ago 2 Members · 3 Replies
  • Jeff Bellune
    July 7, 2009 at 1:40 pm
    You have to save your changes by saving and naming a new preset.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Roy Messinger
    July 8, 2009 at 6:28 am
    I did it a few times. Still, whenever I open the quality presets, it shows the default blue ray, or it shows VBR 2pass, even if I save another transcode.
    Is it some kind of bug, maybe?
  • Jeff Bellune
    July 8, 2009 at 1:35 pm
    Sorry. I misunderstood. I thought you were having trouble saving the changes you made to the settings.
    If I understand correctly now, you want to have the Edit Quality Presets dialog to open up with your last saved/used preset showing instead of whatever default preset Encore chooses to show you. Is that right?
    I don’t know a way to do that. If it’s important to you, please file a feature request here.
    -Jeff
