Activity › Forums › Apple Final Cut Pro Legacy › Edit ProResProxy then ReTransfer/Capture
Posted by Jason Watkins on June 19, 2010 at 3:47 pmI have been hitting you guys up a lot lately and thank you for the help so far. I am looking into the ProRes Proxy workflow and am wondering if there are any pitfalls to recapturing/retransfering the footage of the final sequence. Basically, edit in ProResProxy, and conform the final sequence to ProRes422–footage is mostly AVCHD files, but some HV30 tapes.
Looking at documentation etc. but want to hear from anyone who has done this successfully. Thanks! Jason
Diego Lopez replied 15 years, 5 months ago 5 Members · 10 Replies -
Steve Eisen
June 19, 2010 at 8:26 pmWhy? Hard drives are very inexpensive these days. Keep everything in ProRes or ProRes LT if you are trying to cut down on space.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group -
Shane Ross
June 19, 2010 at 8:50 pmFor the tapeless stuff, just Log and Transfer to ProRes LT. For the tapes, you need an HDV deck and HD Capture device in order to capture it as ProRes LT.
Edit and lock your cut.
Then go through the cut and separate all the footage that is tape based from the tapeless stuff. Put on a higher layer.
Duplicate your sequence twice. Name one TAPELESS, the other TAPE. Delete all the TAPE footage from the TAPELESS sequence, and all the TAPELESS footage from the TAPE sequence.
Media manage both sequences to OFFLINE…set the sequence settings you want to reimport and recapture as. GIve yourself 1-2 second handles, as onlining can cause slippage.
For the tapeless sequence, use Log and Transfer to point to the tapeless backups (the first card just to tell FCP where to look is fine), close it, then hit BATCH CAPTURE. This will reimport only the footage used in the cut, with handles.
For the tape sequence, hook the deck back up, grab the tapes, and use Batch Capture to recapture the footage at the higher resolution.
Shane
Read my blog, Little Frog in High Def -
Jeremy Garchow
June 19, 2010 at 9:07 pmWhat Shane says, except I wouldn’t even spearate the tape from tapeless. Fcp knows the difference when you tell it to batch capture.
Shane Ross
June 19, 2010 at 9:18 pmForce of habit I suppose.
Shane
Jason Watkins
June 19, 2010 at 11:15 pmThanks for the help on the workflow! But are you saying to offline at Proxy, then conform to LT? Or are you saying start at LT and conform up to PR422? I know the cost of drives have come down, but if conforming from proxy is easy and sort of painless, then lowering the bit rate and drive space is a great option for my budget.
Shane Ross
June 21, 2010 at 6:31 am[Jason Watkins] ” But are you saying to offline at Proxy, then conform to LT? Or are you saying start at LT and conform up to PR422? “
If you want the offline/online workflow, you need to capture as Proxy, then online as ProRes 422.
Shane
Jason Watkins
June 21, 2010 at 5:49 pmHey Shane, one more question for you. Is there an easy way to separate the tapeless footage from the file based in the final sequence?
Shane Ross
June 21, 2010 at 6:07 pmWell, Jeremy said you don’t need to. But what I do is color code the footage. Whatever I have less of, I make RED or GREEN, so it stands out.
Shane
Diego Lopez
April 13, 2011 at 7:31 pmOne important note that I had to figure out on my own…
(don’t think it had been mentioned)When trying to “batch capture” on your tapeless workflow, please make sure to adjust your Audio/Video settings.
Capture Preset: Generic Capture Template
Device Control: Non-Controllable DeviceDevice control might be the only relevant one, but those are the settings I used. If you don’t change your Device Control preset, FCP will complain that it can’t initialize the capture device.
Maybe I’m the only fool that needed that tidbit…
