Activity Forums Maxon Cinema 4D Edit Points on a spline. Quick select?
  • Edit Points on a spline. Quick select?
    Posted by Tom on May 9, 2009 at 4:37 pm
    In Maya, when editing point on a spline, you can use the arrow keys to move from point to point.
    In C4D it seems I have to use the mouse to select the points.
    There HAS to be a keyboard shortcut to navigate, right?
    TIA,TH
    Tom replied 17 years, 4 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    May 11, 2009 at 3:43 pm
    There’s no shortcut for this AFAIK. Best I can think of is to use the structure manager which allows you to select points numerically.
  • Tom
    May 11, 2009 at 4:08 pm
    That is a great “point”, thanks Adam 🙂
    I wonder how hard this would be to implement as a plug-in…
    TH
