Activity Forums Adobe After Effects Edit “Output To” setting on Render Item, through scripting
  • Edit “Output To” setting on Render Item, through scripting
    Posted by Dan Thomas on May 2, 2013 at 10:21 pm
    I am scripting with .jsx code, and I can’t figure out how to tell the render queue WHERE I want the movie rendered to. If you were doing it manually, you would edit the “Output to” setting on the item in the render queue. How can I do this through scripting? THanks
    Walter Soyka replied 13 years, 4 months ago 2 Members · 1 Reply
  • Walter Soyka
    May 3, 2013 at 1:08 am
    You do this via the output module object’s file property.
    For an example, take a look at the “Change Render Locations.jsx” script included with After Effects.
    Walter Soyka
