Activity Forums Adobe After Effects Edit Original?
  • Edit Original?
    Posted by Rj Miles on September 2, 2007 at 6:19 am
    Is there a place where I can make changes for what apps are used when “Edit Original” is selected for a source file in AE8?
    I am trying to change AE8 from opening Preview for editing instead of Photoshop, Illustrator, etc…
    Roland R. kahlenberg replied 19 years ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    September 4, 2007 at 9:34 am
    Edit Original is a system-wide feature. The setting is created and updated as you install applications. For Windows, you’ll have to right-click on a file and then select Open With … .
    The downside is that any time you double-click on say a PSd file, it will no longer open up Photoshop and the file.
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
