Activity Forums Adobe After Effects “Edit Original” is opening PSDs in Preview…
  • “Edit Original” is opening PSDs in Preview…
    Posted by Miller on July 2, 2005 at 7:08 pm
    …even though they were created and saved in Photshop CS2…I can work around for now, but why am I having to? Is it the CS2 upgrade that did this? How do I tell After Effects to Look at my Photoshop app for “Edit Original” so I don’t have to make a new set of PSDs and reload the footage manually.
    Chris
    PowerMac G5
    OSX 10.3.9
    AE 6.5
    CS2, of course.
    All freshly installed.
    Miller replied 21 years, 2 months ago 2 Members · 2 Replies
  • Filip Vandueren
    July 3, 2005 at 12:49 am
    It’s prob. more of an OS issue,
    in the Finder, select any .psd file and do a Command-I to “get Info”
    You’ll see a section named “Open with:” and a pop-up to choose a program.
    Select Photoshop CS2 from the pop-up (or if it isn’t listed via the “other…” option)
    and then click on the button “Change All” to open all .psd files with PS CS2
    You may need to have administrator privileges to pull this off, I believe.
  • Miller
    July 3, 2005 at 9:36 am
    Thanks, never had that problem when I’ve reinstalled before.
