Activity Forums Sony Cameras edit mxf or mp4
  • edit mxf or mp4
    Posted by John Young on September 24, 2010 at 8:12 pm
    I have been having problems with my Premiere Pro CS3 running low on system memory on my Vista 32bit system.
    We are in the process of upgrading to CS5 on a 64 bit system, but in the meantime I have to do a good size project. I am worried I will run into RAM problems again (premiere crashing and freezing). Up to this point, I have been importing native mp4 files from the EX-1 into the NLE.
    my question is: Would rewrapping the mp4 into mxf be more stable and easier for my system to work with?
    What do all of you do for your NLE’s?
    http://www.johnathanyoung.com
    Craig Seeman replied 15 years, 11 months ago 2 Members · 3 Replies
  • Craig Seeman
    September 24, 2010 at 9:40 pm
    I’m not sure how Premiere CS3 accesses memory but having to use a GOP based codec is likely going to be more memory intensive that I frame based codec. Based on that, MXF GOP may not buy you much but maybe there are other factors. Of course transoding to I Frame codec is going to use up a lot more hard drive space but it would be easier on the system resources.
  • John Young
    September 25, 2010 at 3:39 pm
    Craig- “Of course transoding to I Frame codec is going to use up a lot more hard drive space but it would be easier on the system resources.”
    Is Quicktime Animation overkill? Is Quicktime Photo JPEG too much of a quality compromise? What I Frame codec do you use?
  • Craig Seeman
    September 25, 2010 at 3:49 pm
    8 bit uncompressed 4:2:2 if that’s available to you.
    Animation isn’t very efficient. Photo JPEG can work but personally I’d gravitate towards a modern video codec.
