Activity › Forums › Adobe Encore DVD › “edit menu in photoshop” isn’t working
  • “edit menu in photoshop” isn’t working
    Posted by Jason Brown on April 14, 2010 at 4:05 pm
    I created a project on my MAC, sent it (THE ENTIRE PROJECT FOLDER) as delivery for duplication…and they keep having the photoshop -1 error trying to build an image file.
    In my troubleshooting…I found that I can’t open ANY of the menus through the “edit menu in photoshop” selection. It doesn’t even launch Photoshop.
    If I go into the Project folder, the photoshop files are there as assets and they look fine as you browse through the Encore project and look at the menu’s.
    Any ideas?
    -Jason
    Jason Brown replied 16 years, 5 months ago 3 Members · 4 Replies
  • Jeff Bellune
    April 14, 2010 at 6:40 pm
    Is Photoshop still associated with .psd files? IOW, what happens when you double click a .psd file in Finder? I know how to fix that in Windows if PS isn’t the program that opens when you do that, but not a clue as to how to fix it on a Mac.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Jason Brown
    April 15, 2010 at 3:09 am
    it’s a mac, file associations are fine. In the project folder, there is a >Sources>Menu folder…that folder contains many XMP files as well as several PSD files.
    -Jason
  • Raja Ashok
    April 15, 2010 at 6:52 am
    Sounds like you may have a corrupted menu/menus. Are you able to edit the menus in Encore (like adding button, layers etc..)? If you are using motion menus then re-rendering may fix your problem.
  • Jason Brown
    April 15, 2010 at 9:50 am
    I was able to open the exact same project file on my machine…build the ISO and will provide that file to the client.
    I can’t think of anything other than just copying the project folder again…hoping nothing is corrupt but I don’t think that is the issue, it seems to be a linking issue.
    -Jason
