Activity › Forums › Adobe Premiere Pro › edit lower layer in program window?
  • edit lower layer in program window?
    Posted by Tad Newberry on May 5, 2014 at 11:10 pm
    try as i might, i can only affect the top layer when i click in the program window. i’m still used to the FCP window where if you could point at it, you could affect it. when there are many layers and graphics, it helps to be able to just click and move stuff rather that opening the motion menu to click left, right, up, down, etc.
    anyone?
    thanks for helping out a bonehead!
    __________________________
    FCS3 / Adobe CC
    3.33 GHz 6-Core Intel Xeon Mac Pro
    24GB RAM
    ATI Radeon HD 5870
    …and a few TeraBytes o’ storage
    (then it’s on to PetaBytes, ExaBytes and MosquitoBytes!)
    Ivan Myles replied 12 years, 4 months ago 3 Members · 7 Replies
  • 7 Replies
  • Ivan Myles
    May 6, 2014 at 6:45 pm
    These are work-arounds rather than solutions, but here are a couple ways to address the issue:
    Edit clip on its own: Temporarily disable the upper tracks in the timeline, edit the target clip as desired, and re-enable the upper tracks.
    Edit clip in context with other tracks: Temporarily move the target clip to the highest track and reduce its opacity. Edit as desired, move the clip back to its original track, and reset opacity.
  • Tad Newberry
    May 6, 2014 at 7:04 pm
    Thanks Ivan,
    Ya, i’ve done those workarounds, just figured i was adding extra steps and missing some shortcut. Apparently not.
    Hey Adobe…here’s a feature request! 🙂
    FCS3 / Adobe CC
    24GB RAM
    ATI Radeon HD 5870
  • Ann Bens
    May 6, 2014 at 7:05 pm
    Select clip in timeline
    Go to Effect Controls and highlight the word Motion (hit transform icon)
    A bounding box will appear in the Program Monitor.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Tad Newberry
    May 6, 2014 at 7:20 pm
    Thanks Ann…but what is the “Transform Icon?” And when you say “Effects Controls”, do you mean the little gray or yellow box in the upper left corner of the clip on the timeline?
    (sorry for my ignorance on this)
    FCS3 / Adobe CC
    24GB RAM
    ATI Radeon HD 5870
  • Ann Bens
    May 6, 2014 at 7:27 pm
    Look for the Effect Controls window and hit the word Motion.
    The icon left of the word Motion is called the transform icon.
  • Tad Newberry
    May 6, 2014 at 7:51 pm
    Thanks. That was what i figured. Anyway, i right click on the little box, get the drop down menu, click on “Motion” (or anything), see the next drop down menu and even if i click on one of those nothing happens.
    FCS3 / Adobe CC
    24GB RAM
    ATI Radeon HD 5870
  • Ann Bens
    May 6, 2014 at 10:02 pm
    Like I said before Highlight the word Motion. Forget about the dropdown menu.
    A yellow bounding box will appear in the PM.
    Now you can move the clip, scale it or rotate it.
