Activity Forums Apple Final Cut Pro Legacy edit like in edius
  • edit like in edius
    Posted by Stefan Kroesbacher on December 15, 2008 at 9:33 am
    Hi All,
    i just made a job with a friend, him working on Edius/Liquid, and i on FCP.
    He could do an incredible fast edit by cutting the clip eitther from or to the playhead, moving
    the following clips to close the gap instantly.
    So, he has say 3 clips..
    starts playing back..
    first is fine..
    as the playhead moves he decides to cut from the inpoint of the second clip
    to the playhead position, and closing the gap (ripple-like)
    Voila, one hit on hte keyboard!
    all i could come up with is to constantly select the clip i’m playing presing x,
    and then set either I or O depending on if i wanted to delete the first or the last part
    of the clip and hit delete.
    but i’d like to have just one shortcut!
    is that possible in FCP?
    i couldn’t find it..
    Stefan Kroesbacher replied 17 years, 9 months ago 3 Members · 3 Replies
  • Luke Price
    December 15, 2008 at 11:00 am
    This might not be the MOST efficient way on FCP but this could be a little faster if I have understood what you trying to do.
    1) Hit CTRL+V to create an edit at the playhead.
    2) Click the section you want to lose and SHIFT+BACKSPACE to ripple delete
    Anyone else got a faster way?
    Luke
    Mac Pro Quad 3GHz, 4GB RAM, 2x7TB XServe RAID
  • Andy Mees
    December 15, 2008 at 3:21 pm
    Stefan
    There are many things you can do in other NLE’s that cannot be done in FCP … and vice versa
    The one you’ve identified would go a long way towards making FCP a better edit system for fast turn stuff, but that isn’t the primary target for this NLE (unlike Edius which sells very strongly in the fast turn market aka News).
    Still, if you have QuickKeys or VideoMacro or a similar utility then you can set up the following macro that could be triggered from a single keypress in order to create the same functions:
    To trim the tail:
    press “control v” to make a cut at the playhead, then press “x” to mark the tail of the clip, then press “shift delete” to ripple delete the marked selection
    To trim the head
    press “control v” to make a cut at the playhead, then press the “back arrow” to jog the playhead back by one frame, then press “x” to mark the tail of the clip, then press “shift delete” to ripple delete
    See how it works for you.
    Cheers
    Andy
  • Stefan Kroesbacher
    December 15, 2008 at 5:41 pm
    Thanx for the help!
    i already thought that this is the only way to go…
    but do i need an extra plug pr can this be done with Automator or applescript maybe?
    cheers
    stefan
