Activity › Forums › Apple Motion › “Edit” generator in FCPX – even possible?
  • “Edit” generator in FCPX – even possible?
    Posted by Michael Paul on October 11, 2016 at 12:24 pm
    Is it actually possible to edit a generator I have created in motion in FCPX? I would say the answer seems to be NO. Generators are the way they are and there is no way to “break them apart” and treat them like a video clip. Still there might be a way so I felt like asking.
    Here is what I’ve got inside ONE generator(for a video where different people get introduced):
    Intro animation- animation to introduction panel (with a drop zone, where I still don’t know how to change it’s resolution. I’ve noticed FCPX adjust the drop zone if I “drop” something into it but if I remove this FCPX still remains the proportions of the previously removed clip causing problems when I decided to drop some other clip into it afterwards)
    Now I’ve added a few still frames without animation to the beginning in case I want to use a fade to my generator. I thought I might be able to “cut off” that intro without any action and jump straigt to the action inside FCPX. I guess this isn’t possible and I would have to export a still frame I can hold and put that in front of my generator that starts right with the animation on the first frame.
    After the intro animation I will introduce people. I have animated that introduction panel just once and it is inside my generator. I thought I could simply make a CUT where that introduction panel animation starts and copy and paste as many introduction as I need inside my FCPX time line but once again- seems like I can not edit or cut anything here so I guess I need to build a seperate independent generator just with that introduction panel and then drop it onto the time line mulitple times.
    Bret Williams replied 9 years, 11 months ago 3 Members · 5 Replies
  • Mark Spencer
    October 11, 2016 at 3:40 pm
    No, you can’t edit it like you are trying to do, it’s just not how generators work.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Bret Williams
    October 11, 2016 at 5:38 pm
    True. But just turn it into a compound clip (option g) and you you can edit it just like any clip. Slice it up, retime it, etc.
    _______________________________________________________________________
    https://BretFX.com Plugins & Templates for FCP X Editors & Motion Graphics Artists
  • Mark Spencer
    Yes, Bret, good idea!
    Mark Spencer
  • Michael Paul
    October 12, 2016 at 9:22 am
    Unfortunatly this doesn’t seem to work or I might have understood you wrong.
    I already had my generator on the main story line but I also had it as a connected clip and changed it to a compound clip (so yeh doesn’t really matter – it was the same both ways :P) but every time I removed something say from the middle – blade tool- cut- cut- remove part it would start playing from the beginning again. So I end up with two clips that start playing from the beginnig instead of removing an unwanted section. So I either got you wrong and didn’t understand what you were trying to tell me or I did something wrong.
    Thanks for the help everyone
  • Bret Williams
    October 12, 2016 at 11:20 am
    Make it a compound clip. Then blade the compound clip. It won’t start over.
