Activity › Forums › DVD Authoring › Edit DVD menu without original files
Posted by Kelissa on July 23, 2007 at 4:26 pmI have a DVD with two buttons on the menu: play movie and play extras. I need to duplicate the DVD without the play extras option. I no longer have the original files. Can this be done without rebuilding the whole thing?
Dan Asselin replied 19 years, 1 month ago 4 Members · 9 Replies -
Eric Pautsch
July 23, 2007 at 6:14 pmYou will need to extract your assets from the disc, do your changes to the menu, then re-author the project.
I like Streamclip to extract:
https://www.squared5.com/svideo/mpeg-streamclip-mac.html
Kelissa
July 24, 2007 at 9:25 pmThank you for the response. Getting new software takes a very long time here. Currently I have Sonic DVDit, Ulead DVD Movie Factory, and DVD Studio Pro. Is there any way to extract the assets using any of these programs? I apreciate your advice.
George Wing
July 24, 2007 at 9:44 pmThe latest versions of DVD MovieFactory allow you to Import from DVD — which version do you have?
Regards,
George -
Eric Pautsch
July 24, 2007 at 11:22 pmKelissa
Use the link I gave you to extract your menus and tracks. Do your changes to the menu in a graphics program and re-author the assets.
Eric
Eric Pautsch
July 24, 2007 at 11:23 pmWon’t take long…maybe 5 minutes to extract. No easy work around sorry.
George Wing
July 24, 2007 at 11:42 pmWell, depending on the DVD Structure, you could author a quick menu, then replace the existing with the new one (using something like DVD Remake or PGCedit).
But the extraction approach and re-author is more straight forward…
Regards,
George -
Eric Pautsch
July 25, 2007 at 1:54 amYes…I had to assume since Kelissa was here asking that question she(?) didn’t really know about or how to use one of those tools. 🙂
Kelissa
July 25, 2007 at 12:13 pmThank you both very much for the advice. I have put in a request to get MPEG Streamclip, since that sounds like the best (and easiest) solution.
Dan Asselin
July 31, 2007 at 12:55 amDear Kelissa;
I remember the first time a client gave me a dvd to get my content from. I thought I was in real trouble. Then I went to the web and found that everything I needed was available for free.
First I use a program called DVD SHRINK to pull my assets from the disk. Then I use a small program called file merger to place the VOB files together, in order, and then finally a program called REJig (in file mode) to de-multiplex the vob files into M2V and AC3 streams which can be imported any authoring programs.
I assure you it is not as complicated as it sounds. Here are some links that may be of assistance to you.
Good Luck
Dan
