Activity Forums Apple OS X Edit Disk Image
  • Edit Disk Image
    Posted by Gabrielm on May 30, 2005 at 4:32 pm
    Hi guys,
    I was wondering if there’s a little application out there that can edit disk images smoothly. By editing, I mean being able to reduce or increase its size, remove unused space, change its content, etc. by opening the dmg or iso file in question for instance.
    I am not necessarily talking about a disk image you create yourself but also an image you get from somewhere else.
    Thanks for your help,
    Gabriel
    Gabrielm replied 21 years, 3 months ago 1 Member · 1 Reply
  • Gabrielm
    June 4, 2005 at 4:26 pm
    Hi again,
    If there is no such application, I would appreciate if you could inform me so.
    In my mind, a tool like this would make playing around with our disk images much easier.
    Instead of extracting the content of an image then creating a new one and then building it, you could:
    Open Image file, change its content, its size, save and voil
