Activity Forums VEGAS Pro Edit copy in Sound Forge is 32 bit Floating Point.
  • Edit copy in Sound Forge is 32 bit Floating Point.
    Posted by Hugh Macdonald on August 9, 2009 at 10:56 am
    Version 9 when I “edit copy in Sound Forge” makes a wav with an unrecognized 32 bit floating point format. My Sound Forge 4.5 does not recognize this.
    Is there a way to make Vegas 9 not change it to 32 bit floating pt?
    (version 6 did not do this. In 9, if I just “edit” instead of “edit copy” then I get the 16 bit standard wav.)
    Hugh Macdonald replied 17 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
