Activity Forums Apple Final Cut Pro Legacy Edit AVCHD clips before pulling into FCP?
  • Edit AVCHD clips before pulling into FCP?
    Posted by Sean Tatalovich on February 20, 2009 at 8:00 pm
    I am getting a Canon that uses the new AVCHD format. My question is before I pull a clip into FCP can I edit the in/out points I want before capturing into FCP? Like you would do with tape. Or do I have to pull the whole clip in?
    Also once pulled in can I use it or does FCP have to render it coming in? Vixia HF11 is the camera.
    Sean Tatalovich replied 17 years, 6 months ago 2 Members · 6 Replies
