Activity Forums Apple Final Cut Pro Legacy Edging on a spinning logo
  • Edging on a spinning logo
    Posted by Paul Jones on June 1, 2009 at 5:33 pm
    Hi Guys
    This is something I’ve never mastered
    I have a logo with a white background, I have to make it spin using basic 3D
    I lay it over the top of a white background created in Color Matte
    When the logo spins you see a black edge to the logo.
    I have tried to crop in the edges but makes no difference.
    I have had a similar problems to this and never found a solution so any help would be appreciated
    Cheers
    Bret Williams replied 17 years, 3 months ago 4 Members · 4 Replies
  • Chris Poisson
    June 1, 2009 at 6:12 pm
    Paul,
    Need more info, your logo has an alpha channel I assume? Sounds like it is premultiplied vs. straight, which it should be. Also, assuming you’re doing this in FCP, how are you viewing it? You should be using a proper broadcast monitor or at least a TV.
    You might try using the matte choker on it to trim the edge.
    Have a wonderful day.
  • Joey Burnham
    June 1, 2009 at 6:31 pm
    [Paul Jones] “Errr, not sure, don’t have great knowledge on alpha channels etc”
    You need to. Google it.
    JPEG does not support alpha channels, and even if the JPEG has no background at all besides for the logo, FCP is probably going to do something weird to the edges.
    Do a little research. Then bring your logo into photoshop or whatever, make a .tif or .targa with alpha and bring back into FCP.
    If it has a white or back background you could pull a luma key but really you should educate yourself on alpha channels first.
    Best,
    Joey
  • Paul Jones
    June 1, 2009 at 6:35 pm
    Its just a jpg of a logo added in the timeline sitting above a white slug
    Yes its FCP and the matte choker doesn’t help, it just makes the white of the logo slightly darker so it now doesn’t match the background.
    Its the same when I monitor on an external monitor but this is only going to be shown as a quicktime anyway
    cheers
  • Bret Williams
    June 1, 2009 at 7:15 pm
    He’s not crazy. It’s a bug I run into all the time, and I guarantee you I have extensive knowledge of alpha channels, although there aren’t any involved in this thread.
    Take a jpeg on a white bgrnd and place it over a white background. Shrink it back. FCP places a black edge around it. Very very slight. So, forgetting this bug, I always start to crop it. But the black edge moves with the crop. Soften the crop… nope still there. Render it… still there.
    Perhaps it is a jpeg thing. Save it as a tiff or something else maybe.
