Activity Forums Maxon Cinema 4D edges look crappy with i import into AE
  • edges look crappy with i import into AE
    Posted by Michael Duff on August 8, 2005 at 6:30 am
    hi all – I’ve made an animation that has an alpha and I’m importing it into AE. But the edges aren’t very smooth. Very “staircase” like. Not a crisp clean edge.
    Can someone please suggest export settings to get this clean? I’m going into a PAL project in AE.
    Cheers in advance.
    Mark Simpson replied 21 years ago 2 Members · 1 Reply
  • Mark Simpson
    August 8, 2005 at 12:45 pm
    make sure the quality switch for the layer in your timeline in ae is set to ‘best’ quality. Make sure your composition window is set to full resolution also…
    short of that, check your AA settings in the render dialog of Cinema…you might have to up them..
    Also make sure that you have ae interpreting the alpha correctly (in the footage window..command>F)
    MArk Simpson
