Activity Forums Apple Final Cut Pro Legacy Edge wipe issue with export
  • Edge wipe issue with export
    Posted by Wendy Rowland on January 31, 2016 at 4:17 pm
    Hi there – I am trying to use an edge wipe transition … it looks fine in FCP7 but when I export it the outgoing edge has little black lines along edge.
    I’ve attached a screen shot image of how the edge looks in fcp7 (I tried to feather it thinking that would help – it didn’t make a difference).
    Here is an image of how the edge looks once I export it:
    And here is how the edge looks before I export it:
    Thanks in advance for any suggestions as to why this is happening.
    Wendy R
    Shane Ross replied 10 years, 7 months ago 2 Members · 1 Reply
  • Shane Ross
    January 31, 2016 at 5:00 pm
    What are your sequence and footage settings? 1080i59.94 perchance? The footage looks interlaced, thus to reason that the source footage and sequence are set to interlace. Interlacing doesn’t display properly on computer displays as they aren’t designed to show interlacing, thus why it will look odd on the computer.
    Shane
    Little Frog Post
