Activity Forums Apple Final Cut Pro Legacy Edge feathering on one side
  • Edge feathering on one side
    Posted by Arvid Utas on August 29, 2010 at 3:13 pm
    I can’t seem to find a solution for this problem even though it feels like it should be a common one, maybe there’s a super easy way to fix and I’m just being blind but anyways, here it is:
    When using the cropping function in the Motion tab or when using the garbage matte I tend to find myself in a situation where I want to feather the edge of ONE side. But the feather-function autocrapically applies itself to all four sides. How do I do this??
    Many thanks,
    Arvid
    Gary Adcock replied 16 years ago 6 Members · 7 Replies
  • 7 Replies
  • Chris Tompkins
    August 29, 2010 at 3:27 pm
    Basic FCP will not do this.
    There is a free plugin out there that will let you do this.
    Can’t remember the name…
    Chris Tompkins
    Video Atlanta
  • Pradip Patil
    August 29, 2010 at 5:53 pm
    can’t you put the same video on upper layer and mask it so as to reveal only the edge feather of lower video layer?
    Pradip Patil
    Mumbai,India
  • Michael
    August 29, 2010 at 8:06 pm
    You need Andy’s Simple Crop. If I remember right, it allows you to adjust edge feathering on individual sides.
    https://web.mac.com/andymees/Free_and_Easy/main/main.html
  • Chris Tompkins
    August 29, 2010 at 9:19 pm
    Ya, Andy’s – that’s it!
    Chris Tompkins
    Video Atlanta
  • Arvid Utas
    August 30, 2010 at 12:54 am
    Thanks for the help everybody!
    I tried Andys plugin and it looks like it is exactly what I’m looking for but the feathering feature doesn’t seem to work! The ugly border works fine but nothing happens when the feather is changed…Any ideas?
  • Thom Obarski
    August 30, 2010 at 5:05 am
    you can achieve the same thing using a filter built into fcp called mask shape which will let you create and place a mask and then combine it with the mask feather filter; these are both located in the matte section of your filter list
    “This is post, you can’t fix it after this.”
  • Gary Adcock
    August 30, 2010 at 3:20 pm
    Everyone-there is a really simple solution for feathering on one side in fcp
    you will need to make a mask prior to adding the feathering -so when you make the mask – usually a 4 point Mask Shape- extend the 3 sides that you do not want an a feathered edge on outside of the image area in an amount equal or greater to the feathering.
    That should allow you to output with only a single side having the feathering.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    https://blogs.creativecow.net/24640
