Activity Forums Adobe Premiere Pro Edge effects
  • Edge effects
    Posted by Pete1801 on November 3, 2005 at 10:22 pm
    Is there a way to make the “Edge effect” work on the edge of a a video that has been cropped?
    I.e. I have a cropped image in the top left (picture in picture) of main vid and want the cropped vid to have a black border but if i apply edge effects, it applies them to the whole video as if the cropping wasn’t there. (Does that make sense!?)
    Dex Craig replied 20 years, 10 months ago 4 Members · 3 Replies
  • Wolf
    November 4, 2005 at 8:38 am
    Hi…
    i tried the same and didn
  • Mike Velte
    November 4, 2005 at 11:50 am
    How about using the titler to create an overlay of the effect you want?
  • Dex Craig
    November 4, 2005 at 4:45 pm
    OK, a couple things can work. First off, try dropping “Bevel Alpha” on your clip. That will give a, well, bevelled edge to the PIP. If you want to put a colored border around the PIP, add Radial Shadow (it’s in Perspective, along with Bevel Alpha). You can change the color of the “shadow” to whatever color you like, and if you play with the projection distance and light source perameters, you can actually get a border around your PIP. Not super easy, but it will do what you want.
    Otherwise, you could always create a border element in Photoshop or in the titler that’s just a little larger than your PIP element and put it on the timeline between the background layer and the PIP layer.
    Hope one of these ideas helps!
    – Dex
