Activity Forums Adobe After Effects Edge CC problems using Keylight 1.26 on Mac Pro OSX 10.4
  • Edge CC problems using Keylight 1.26 on Mac Pro OSX 10.4
    Posted by Robert Houghton on December 14, 2007 at 10:20 pm
    I’m hoping someone here has encountered this problem and has a solution I sure can use some Help.
    I have a Mac Pro Intel dual 2.66 with 8GB of Ram running After Effects CS3.
    I’m having difficulty using the “Edge Colour Correction” tool to integrate some green screen footage over a light blue background. When I activate the tool to test it, I can set up the “Edge Grow” amount to 10 and Brightness to 100 so I can see it over the key. The problem comes up when I want to soften the border generated by the effect. When I put “Edge Softness” to a relatively small amount like 0.5 (or 0.1 for that matter) the entire edge disappears instead of softening. I know I’ve used this with success in AE 7.0 on a Power Mac but now it is not working. Thanks in advance.
    -Rob
    Robert Houghton replied 18 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
