Activity Forums Adobe Premiere Pro Edge Artifacts in Premiere? JPG attached
  • Edge Artifacts in Premiere? JPG attached
    Posted by Kevin Obrien on January 7, 2014 at 11:26 pm
    Hello All
    I rendered a sequence out of After Effects… (I rendered it as a MOV/PNG)
    When I play it with Quicktime it’s fine… when I import it to Premiere part of the clip has these little white edges running alon the top and bottom.
    I went to “Edit-Preferences-General” in Premiere to make sure “Default scale to frame size” is checked
    I can’t figure out why the white edge “artifacts” show only after importing to Premiere. Suggestions?
    Attached is a jpg
    Kevin Obrien replied 12 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
