Activity Forums VEGAS Pro Ed, Mike and others continued help on HDV Capture
  • Ed, Mike and others continued help on HDV Capture
    Posted by Terry Esslinger on April 1, 2008 at 1:49 am
    OK
    Finally got the right capture program (internal). Have Vegas properties set to HD 1080i (1920×1080 29.970), Vegas will control and apparently capture video from the Fx1. It can be seen on the preview screen in the capture module. When capture is stopped a file is deposited in Project Media (Clipxx.m2t). HOWEVER it will not play in the Project media window and it cannot be drug to the time line. I suspect this is a codec problem , right? I have loaded the Codec lite pak but still no go. What might be my problem now? I have 2.4 dual core with 2Gram and 3 drives. HELP!!
    Terry Esslinger replied 18 years, 5 months ago 2 Members · 3 Replies
  • Douglas Spotted eagle
    April 1, 2008 at 2:38 am
    ~Project properties should be HDV, not HD. 1440 x 1080
    ~you dont’ need a codec pack, and chances are very good this is part of what’s screwing you up.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Terry Esslinger
    April 1, 2008 at 3:07 am
    Yes, yes, yes it works with those settings. Even with my codec pac. Thank you (again) Spot.
  • Terry Esslinger
    April 1, 2008 at 5:04 am
    And Mike and ED!
