Activity Forums DVD Authoring Eclipse errors with dual-Layer DVD and CSS
  • Eclipse errors with dual-Layer DVD and CSS
    Posted by Matteo Vega on April 30, 2013 at 4:39 pm
    Hello World,
    I’m having problems authoring a DVD9 using Adobe Encore CS6 and Gear Pro ME. My process so far has been:
    – Authored DVD in Encore. Exported as VIDEO_TS (not pre-flagged).
    – Used GPME to set correct layer break point and pre-flag for CSS. Exported as DDP 2.10 (SSCRST 4, Control.DAT 2054 bytes/sector)
    – Sent the DDP to the replicators via FTP (Checksum didn’t differ)
    Now the replicators used Eclipse to verify the DDP images and found following errors:
    – The EclipseSuite tools found a sector that is tagged for encryption but the sector is not part of any VTS in the VOB Location Table.
    – The ISO9660 information and the CPM or CGMS fields in the Main data do not agree on the encryption status of a file.
    – ImageVerify or ImageEncoder found an invalid Title Key in an un-encrypted sector. (Only on Layer 1)
    Does anyone know what the problem can be or has experienced a similar issue before. Any help would be greatly appreciated!
    Regards,
    Matt
    Matteo Vega replied 13 years, 4 months ago 2 Members · 2 Replies
  • Eric Pautsch
    May 1, 2013 at 3:03 am
    Usually these are error from recordable discs. I always submit DDP images on pens drives. Do that and another set of recordables and see what happens
  • Matteo Vega
    May 1, 2013 at 8:16 am
    Hey Eric,
    Thanks for your response, however I transfered the DDP image via FTP not on disc. The replicators also verified the checksums generated by Gear. I just wonder if the CSS errors are due to the new layer break which was calculated using layer break calculator. (https://orwell.ru/test/multimedia/LayBre_GEAR.html)
    Matt
