echo w/ vegas audio
Posted by Tad Richards on January 23, 2010 at 1:34 amHow do you create an echo effect, or a hollow effect?
Tad Richards replied 16 years, 7 months ago 2 Members · 2 Replies -
David Katauskas
January 23, 2010 at 4:31 amYou can add an effect to the audio track the same as you would to the video. Vegas comes with a few audio effects out of the box, such as “reverb” or “simple delay”. Once you click on the icon to add an effect to your audio track, go under the “Sony” folder and they should be there. Then tweak the knobs until you get the sound you want.
If those don’t work for you, then take a look at some of the freeware VST plugins. Search for “VST Echo” and you should probably find a bizillion.
Tad Richards
January 26, 2010 at 3:18 pmThanks. I seem to be having a lot of trouble finding the “reverb” setting, although I know it should be simple. I’ve ended up adding those effects in Goldwave and then bringing them back into Vegas when I edit the voices and sound effects together.
