Activity Forums Apple Final Cut Pro Legacy Echo tracks?
  • Posted by George Bonilla on March 19, 2009 at 9:46 pm
    Well, here I am again. I am doing the final export on a project. I am exporting using compressor. But I am having a FCP problem. During viewing of the playback I keep getting repeated clips of audio. I found two and fixed them. Then it showed up somewhere else. I checked one track and it played fine until I played it for the 4th time and it repeated again? Like it is edited together twice. I opened it in the viewer and according to the wave it is perfect but on playback the line repeats. Then after fixxing those I noticed one that was fixed last time now repeats. Is it a render problem? Thanks
    George Bonilla replied 17 years, 6 months ago 2 Members · 2 Replies
  • John Fishback
    March 19, 2009 at 9:53 pm
    Have you trashed prefs and rebuilt permissions? Also, as this appears to be audio-related do an audio mixdown. Another thought re your workflow is to export a self-contained movie of your show, and then use compressor.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • George Bonilla
    March 19, 2009 at 10:02 pm
    I will do that now. I trashed my audio render files. Thanks
