Activity › Forums › Adobe After Effects › Echo speed trail effect
  • Echo speed trail effect
    Posted by Spidy2167 on October 19, 2007 at 4:18 pm
    Shane or Aharon,
    Did ether of you get this effct to work? I have some Volleyball footage that I would like to apply this to. or something close would be good. Thanks.
    Kevin Camp replied 18 years, 11 months ago 3 Members · 2 Replies
  • Malcolm Desoto
    October 19, 2007 at 6:25 pm
    time blend maybe?
  • Kevin Camp
    October 19, 2007 at 8:04 pm
    cc wide time is another that will composite frames on top of the current frame to give a motion blur like trail. but if the ball if moving fast (which it would be unless you shot slo-mo) it may practically disapear.
    if you only wanted a trail off the ball, you might get the best results with a particle system, having the emitter/producer folow the motion of the ball and now velocity/speed o n the particles.
    andrew kramer has a few tutorials that use an emitter to produce a trail. the ipod light streak and 3d stroke w/o 3d stroke come to mind.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
