Activity › Forums › Adobe Audition › Echo on audio
Echo on audio
Posted by Paul Bibby on July 28, 2009 at 10:19 amThis is audio I recorded on the onboard mic of an conon xm2 it has a echo how would i remove it on audition. I did put a 10db boost on it. but that does’nt seem to be the problem. thanks for all the help
Paul Bibby replied 17 years, 1 month ago 3 Members · 6 Replies -
Emmett Andrews
July 29, 2009 at 8:45 pmNo, because it can’t bd done. As a video guy, you can compare it to trying to remove the dark from something filmed at night with no lights and trying to make it look like a sunny day.
Steven Talley
July 30, 2009 at 1:24 amCuriosity got me to look at your clip and just by running the Acapella filter I was able to lessen the room ambiance. Some coloration appeared but EQing helped with that. Give it a try if you haven’t already.
Paul Bibby
July 30, 2009 at 6:07 amHi Steve, at the risk of sounding like a complete idiot were do I find the Acapella filter I have audition 2.0 and I’ve looked everywhere,
could you perhaps post a screen shot I would really appreciate it thanks for your time,I’m more of a Premier and after effects guy sound still baffles me. -
Steven Talley
July 31, 2009 at 4:47 amSorry Paul, I was using 1.5 and the later versions don’t seem to have the effect. How bizarre, they removed this effect in later versions. That’s just stupid if you ask me.
So what now? YouTube has everything, I found a clip that may help.I tried it with your sample and it helps.
You do have Vocal Remover in Favorites in Edit mode, Yes? Good.
Load your audio clip into Audition in Edit mode, run vocal remover from the Favorites menu tab, now play. You should hear ambient vocals with the echo you want to remove. Now open the Effects menu and click Invert, then save this new file.
Now load both the original and the new file into Audition. Add each one to the multitrack. Now playback and save (if it works). Volume should be equal for each file. Mixing down to mono helps also.
Check out the video link (above) if you want to know how it works.
Enjoy
SteveSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Paul Bibby
July 31, 2009 at 7:15 amThanks so much for the very detailed explination it help alot thanks
