Activity › Forums › VEGAS Pro › Echo in image after render
  • Stephen Crye
    January 13, 2014 at 6:03 am
    Not sure what you mean by “24 fps to film” .
    Could it just be motion blur? Try shooting at 1/250 or 1/500 and see if it is still there.
    What are your project settings? Render settings? What is the container and encoding of the video? (not all of use Canon so we don’t want to guess).
    Steve
    Win7 Pro X64 on Dell T7500, MultiTB SATA, 8GB RAM, nVidia Quadro 2000, Vegas 12, 11, 10, 9 DVDA 6.0 & 5.2(build 135) Sony HDR-CX550V, Panasonic GH3 with LUMIX G X VARIO 12-35mm / F2.8 ASPH, LUMIX G X VARIO 35-100mm / F2.8
  • Graham Bernard
    January 13, 2014 at 7:21 am
    Matthew, there will be a solution. This is what Vegas was designed to do. Take one Format and re-deliver in another format.
    Somewhere in your workflow you have this “echo” – well what you appear to have is a sampling mismatch.
    Is that capture on a dissolve? Transition? You are downsizing/downrezing from 1080 to 720. Are you still viewing in a 1080 environment monitor? Do try unchecking disabling re-sampling. OR you don’t have a method for motion “blur”.
    In the meantime, do as Stephen asks – we need more factoids!
    There will be a fix.
    Grazie
  • James Kumorek
    January 13, 2014 at 1:08 pm
    I’ve seen exactly this when Vegas things that the frame rate doesn’t match up with the frame rate being rendered, or frame rate of the project. For example, if I took 59.94 fps 720p footage and put it on a 29.97 timeline, and set the clip speed to 50%, I saw exactly this, because Vegas thought it had to “resample” the footage to get the right frame rate.
    Try right-clicking on the video clip being used, pick Switchers, and the Disable Resample, and see what happens.
  • Matthew Jeschke
    January 13, 2014 at 4:29 pm
    I did go from 1080p (source footage) to 720p (rendered). On that particular spot I also zoomed in the video (no dissolves or transitions there though. I kept the frame rates the same from source to render as I too noticed it can create all kinds of little glitches when it interpolates the frames.
    I think you had the answer… I forgot about clicking the video in the timeline and selecting to disable resampling. I hate resampling. It almost always does that stuff to me. But it’s been a while since I edited.
    FYI. Here’s my details & I’m using Sony Vegas Pro 10.
    I’m learning the ropes of online publishing. Mostly as an excuse to play with more cameras.
    Here’s several of my latest ventures,
    https://www.keystoaz.com
    https://www.fitlish.com
    https://www.corvettemedic.com
  • James Kumorek
    January 13, 2014 at 6:28 pm
    Yes, this is likely the problem. Your media is 23.97 fps; you are rendering at 30 fps. So, a mismatch. You could also chance the render frame rate to 23.97fps and see what that does — it’s always best to render out the same frame rate as the project.
  • Matthew Jeschke
    January 13, 2014 at 6:29 pm
    Ops sorry, I had set the render to 24 fps when I did the video above. Vegas must have defaulted back to 30fps when I did the screen capture in the above picture.
