Activity Forums Adobe After Effects Echo: How to use?
  • Echo: How to use?
    Posted by Manny Rellesiva on September 30, 2005 at 9:18 am
    I have a difficulty in using the “echo” effect. I even tried precomposing the layer, applying the effect but still i cant see the ghost-like effect. Tweaking the settings didnt seem to work. I have this tutorial about echo and it seemed like it was very easy to use. It was applied to a tiff image (a ball) and you can see the reasult immediately. I even copied the settings but it didnt work in my layer. Are there any special do’s and dont’s in using this effect? What am I missing? do you know any online tutorial? Please help. Thanks in advance.
    Pierre Jasmin replied 20 years, 12 months ago 4 Members · 3 Replies
  • Jim Zito
    September 30, 2005 at 11:13 am
    One thing that kept getting me was that you have to precompose the layer WITH the animation, then apply ECHO to the precomp. Also, when scrubbing the Time setting, I hold down the ALT button because usually it only requires a small increment change to see results. Anyone else?
    HTH.
    Jim
  • Chris Smith
    September 30, 2005 at 1:36 pm
    I’m guessing it’s a pre-comp issue as well. Because echo is completely straight forward. I would just try it on a video clip first (which wouldn’t need pre-comping). Just to make sure all is well.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Pierre Jasmin
    September 30, 2005 at 6:29 pm
    In case, in AE if you have something like:
    Layer
    * effect1
    * effect2
    and effect2 is something that access other frames or layers
    You have to transform this to:
    Comp 1
    Layer
    * effect1
    Comp2
    Comp1 (layer)
    * effect 2
    Pierre
    RE:Vision Effects
