Activity Forums Adobe After Effects Echo displacement/ghosting effect
  • Echo displacement/ghosting effect
    Posted by Joshua Leong on October 10, 2010 at 2:20 pm
    Hi all,
    I’m looking to recreate an effect that one might see in a horror movie where the camera in first person view is focusing on an object, such as a person – then, for a split second semi-transparent ‘echos’ or ghosts of that object will diverge from it and reconverge (often accompanied by a brief but disturbing noise similar to radio static). I’m not quite sure how to put it into words (which might also explain why I’m having trouble finding tutorials on this effect), so the above explanation might be somewhat confusing, but would anyone be able to shed any light on this at all?
    If I can, I’ll try and find an example on youtube and post it here.
    Cheers,
    Josh
    Roland R. kahlenberg replied 15 years, 10 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    October 11, 2010 at 4:55 pm
    Give the Echo effect a shot. But whether it works depends if there is movement in the original shot. If there isn’t much movement then a duplicate with displacement mapping should help to add some movement.
    HTH
    RoRK
    AE Training in South East Asia. AE templates for sale and rental. Click here for more
  • Joshua Leong
    October 12, 2010 at 12:28 pm
    Hey,
    Just gave the displacement map a try and it worked a treat – exactly what I’m looking for. Thanks for your help, Roland.
    October 12, 2010 at 1:28 pm
    Thanks for reporting back Joshua. I’m glad it worked out for you.
    Cheers
    RoRK
