Activity Forums Apple Final Cut Pro Legacy EBU color bars HELP
  • EBU color bars HELP
    Posted by Wong Kwang han on April 4, 2005 at 3:50 am
    Anybody know how to calibrate ebu color bars for accurate representation for shooting on PAL on a pro field monitor? the topics i found have been on ntsc calibration. really need help on this, thank you. shooting on a XM1. using a 9 inch JVC TML 500PN field monitor and a 14 inch sony PVM14L1 for editing on an emac, final cut pro 4
    Wong Kwang han replied 21 years, 5 months ago 3 Members · 3 Replies
  • Chris Davies
    April 4, 2005 at 11:48 am
  • Zman
    April 4, 2005 at 2:44 pm
    I understand why your going to all this trouble, but if you dont have the proper visual set up your only killing yourself here, for the field shoot if you dont have the monitor set up under a tent or in a truck your really not doing yourself anything. the outside conditions change every few minutes or seconds depending on the day and the weather, what looks good on a sunny day looks bad on a cloudy day, what you need to do is test your camera and learn to read a light meter. a field monitor is not gonna help you with more that “yes we have a picture and it’s in focus and looks pretty good”. your camera is a good camera, use the zebra pattern option to find when you blowing out the white, as far as color temps either white balance everything or dont, you need to play with the camera to figure out what your shooting, the field monitor is not helping you with anything, as a matter of fact it can work against you, thats why you see more led screen hookups for monitoring purposes(they dont drift) these days.
  • Wong Kwang han
    April 4, 2005 at 5:31 pm
    thanks, chris and ange
    yes, for outdoor shoots there is the problem of set up, especially with limited manpower and time, in such situations would simply looking throught he viewfinder and using the zebra strips and a light meter be more practical? yep i would have to learn to use a light meter, something i’ve been putting off.
    chris, i found the pal chart, however the instructions are for ntsc only
