Activity Forums DaVinci Resolve easyDCP and davinci resolve workflow
  • easyDCP and davinci resolve workflow
    Posted by Noob Colorist on December 4, 2015 at 5:19 pm
    Hello guys,
    I have some questions, Hope someone can guide me.
    I have done grading of a film using davinci resolve (it’s in 2K resolution 2048×1152). Now i have to make a 2K Flat (1998×1080)dcp. We have easyDCP creator+ in our facility. So, i need to export the film as dpx or tiff image sequence from resolve, right?
    Now the things i would like to know…
    1. should I export the sequence (from resolve) with the native frame size (2048×1152) or DCI size (1998×1080)??
    2. After exporting the image sequence do I need to convert Again the dpx’s or tiff’s to J2K with the “easyDCP standalone JPEG 2000 Trasncoder” then import to “easyDCP Creator+”??
    OR, i should import the dpx’s tiff’s sequence directly to “easyDCP Creator+”??
    Hope i will get some proper guidance.
    Thanks to all & sorry for my bad english.
    Joseph Owens replied 10 years, 9 months ago 2 Members · 3 Replies
  • Joseph Owens
    December 4, 2015 at 9:12 pm
    [Rakib Uddin Rana] “1. should I export the sequence (from resolve) with the native frame size (2048×1152) or DCI size (1998×1080)??”
    Here’s a tutorial that starts with HD 1920×1080 to make a “flat” 1998 DCP package:
    https://www.easydcp.com/support-videos.php
    Because both formats are 16×9, (2048 and 1920), you will be scaling and/or pillarboxing at some stage, either out of the DCP creator or Resolve whether you export a dpx sequence or a completed DCP package, depending on how you wish to manage the vertical resolution.
    If you are absolutely using easyDCP Creator+ to make the final DCP, my own impulse is to export a full-frame 2K dpx sequence and let the authoring software do the jp2K conversion. This might also un-complicate your audio track assignment configuration, as Resolve is not particularly flexible in this regard.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Noob Colorist
    December 5, 2015 at 5:41 am
    Many thanks Joseph for a quick reply.
    But as a novice I need To be clear one thing that there is a software called “easyDCP Standalone JPEG 2000 Transcoder” bundled with the easyDCP Package. Do i need to convert the dpx with that? Or I just import the dpx to “easyDCP Creator+” and it will handle the dpx by itself?
    Is there any quality or playback issues will happen between these two type of conversion?
    Thanks..
  • Joseph Owens
    December 7, 2015 at 3:57 am
    [Rakib Uddin Rana] “Do i need to convert the dpx with that? Or I just import the dpx to “easyDCP Creator+” and it will handle the dpx by itself?
    My understanding (I do not use easyDCP myself) is that Creator is capable of converting a dpx sequence — it likely calls an imbedded converter which, given the manufacturer, will be indistinguishable from its standalone application. A bit like exporting a file from Premiere — you can either choose to export directly out of the timeline or call Adobe Media Encoder –same application, just going through a different door in the house.
    The forum can correct me on this if it is not the case.
    You might be interested in reading a recent blog by a prominent post supervisor on the premise of this type of resolution conversion — search for “2K is a crock.”
    Make very sure you are using the proper 0-100 video range.
    jPo
