Activity Forums Adobe Photoshop Easy way to replace an image with a higher res. version AFTER editing?
  • Easy way to replace an image with a higher res. version AFTER editing?
    Posted by Tim Kocher on November 24, 2016 at 7:31 am
    I recently touched up a photo and of course have multiple layers (somewhere around 10). However, I discovered I really need this at a higher resolution, so I rescanned the photo (fortunately it never moved from the scanner bed) and used Photoshop to auto match it to the original so the crop was identical.
    What I am having a hard time figuring out is, how do replace the existing image in my Photoshop project with the newly scanned image? I need all of the edits (heal, clone stamping, masks, etc.) to SCALE to the new higher image resolution/size. Is there any easy way to do this? Is there perhaps a script out there that does this anyone knows of, or hopefully built-in?
    In After Effects this is a VERY easy thing to accomplish, using a simple script and clicking a button. Here’s to hoping something similar in PS.
    -Tim
    Katarzyna Kuzawska replied 9 years, 7 months ago 2 Members · 1 Reply
  • Katarzyna Kuzawska
    February 24, 2017 at 1:38 pm
    Maybe you should use Image->Resize Image (here you can set Resolution and size) with Scale Styles option marked.
    Then after resizing the whole image , you can replace with your new better one. It’s good way when u were applying changes on Adjustments Layers. But if you were editing pixels of your Image directly it’s impossible to apply automatically these changes on new one.
