Activity › Forums › Adobe After Effects Expressions › easy way to apply expression to multiple layers
Posted by Nicola Cullen on May 13, 2008 at 3:01 pmHi there,
I have a few comps with a couple of hundred layers in each and I need to apply a wiggle expression to the position of every layer… is there an easy way to do this without copying and pasting the expression onto each layer?
Marieke Hannen replied 5 years, 5 months ago 5 Members · 6 Replies -
Dan Ebberts
May 13, 2008 at 4:09 pmSure,
Select the property with the expression
Edit > Copy Expression Only
Select all the other layers
Edit > Paste
Dan
Bert Brown
May 13, 2008 at 6:38 pmthis was actually just a cow podcast at the beginning of the month. you should watch them
peep my over-the-interweb band, red abbott.
“we electro-rock over long distances…” -
Jonathan Alenskas
February 27, 2016 at 10:29 pmhow could one type an expression on a precomp layer which effects each layer inside the comp accordingly ?
i am trying to apply a fill based on depth expression to all layers inside a precomp from outside the comp.
at the momment I am applying the following to each layer inside the precomp :
c=thisComp.layer(“Camera”); // choose the active camera //
cp=c.toWorld([0,0,0]); // camera’s position in world space //
p=thisLayer.toWorld(thisLayer.anchorPoint); // this layers position in world space //
d=length(cp,p); // calculate distance from camera to layer //
far=10000; // far distance for black value //
f=linear(d,0,far,1,0); // calculate fill colour from distance //
[f,f,f,1]if i could do this from the outside then i would not need a seperate depth comp and the depth would update according to what i do in the ‘beauty’ comp.
Jonathan Alenskas
Dan Ebberts
February 28, 2016 at 7:19 amIf I understand what you’re asking, that’s not how expressions work. Each fill color would need its own expression.
Dan
