Activity Forums Adobe After Effects Easy text outline
  • Easy text outline
    Posted by Levon H on October 6, 2006 at 1:17 am
    maybe im missing something simple… but the only way i can find to do an effect similar to the stroke layer effect in photoshop is following arrons stoke tutorial.. and using a duplicated layer with a matte choker.
    is there a more simple way of doing it?
    thanks, Levon
    Levon H replied 19 years, 10 months ago 3 Members · 3 Replies
  • Mike Clasby
    October 6, 2006 at 2:31 am
    For text, Layer>Create Outlines, then you get masks for your letters on a new layer.
    For layers with an alpha punched out, like a tree-shaped psd, Layer>Auto-Trace (tolerance and threshold of 1 makes nice tight masks) makes masks.
    Then use Render>Stroke, Render>Vegas, or my fav Render>AudioWaveform (on mask, nice neon effect). There’s also Roughen Edges>Color, but a bit different look… And Radial shadow (if you center the Light Source). But Stroke and Audio Waveform (without tying to an Audio layer) are the most like photoshop.
  • Sam Moulton
    October 6, 2006 at 6:00 am
    The text tool palette has fill and stroke just like illustrator and photoshop. want outlined text just turn off fill and turn on stroke.
  • Levon H
    October 10, 2006 at 2:40 am
    hahah.. i missed that… im used to using the stroke effect in the layer effects. thanks mate 🙂
