Activity › Forums › Adobe Premiere Pro › easy test for a bug of ppro 2.0
  • easy test for a bug of ppro 2.0
    Posted by Billyj on March 8, 2006 at 9:03 am
    Hi to everybody,
    As it is very confused with the bugs of ppro 2.0 (see posts below), I propose a special post to make this easy test : create a 4000×4000 pixels still under photoshop. Put it on the timeline of ppro 2.0 for a duration of 5 sec. Add a scale keyframe to the “in point” for a value of 30, add a scale keyframe to the “out point” for a value of 10. Try to render. For me, it takes more than 4 minutes !
    What is strange is that if the value of the scaling remains over 50, there is no rendering problem.
    If you set : in 51 / out 52, it takes a few seconds to render.
    If you set : in 48 / out 49, it takes a few minutes.
    Can you confirm this ?
    Billyj replied 20 years, 6 months ago 2 Members · 3 Replies
  • Tim Kolb
    March 8, 2006 at 2:39 pm
    billyj:
    What are your project settings so I can set this up exactly as you have it?
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Billyj
    March 8, 2006 at 5:00 pm
    I am in dv pal 48khz (but I don’t use sound) and dv pal export, optimize still, scratch disk on another partition than the OS.
    Thanks.
  • Billyj
    March 10, 2006 at 10:42 am
    So am I the only one to have this problem ?
    Could someone make this easy test to confirm ? (5 mn).
