Activity Forums Adobe After Effects Expressions Easy stop roller
  • Posted by Davib Le roux on August 29, 2009 at 3:54 pm
    I am having serious trouble making my animation ease from one value to the next.
    I have a layer (called “Numbers”) containing numbers and logos arranged something like this:
    LOGO
    2
    LOGO
    LOGO
    4
    LOGO
    3
    0
    LOGO
    6
    7
    LOGO
    1
    8
    LOGO
    5
    9
    LOGO
    (sorry, didint know how to attach a picture of the layer.)
    this layer moves behind a “window layer” that only allows one number or logo to be displayed at a time. like a slot machine display. so in other words to change the value in the window i must edit the y value of my Numbers layer.
    To do this i have added a slider control to another layer (FaceValue) and used an expression. so if my slider control value is any whole number between 0 and 9, that number will be visible in the “window”. if the slider value is anything other than a whole number between 0 and 9, the value will be moving (wiggle(0.2,10000).
    to animate it i have keyframed the slider values. at 0:00:00 the slider value is 10 and at 0:02:00 the value is the number i want to display (eg 5 or 8 or any number 0-9).
    the problem i have is that the animation goes from wiggling at 50 000 pixels per second, to stopped, without slowing down. i want it to slowdown to a stop. Like a slot machine would do. just dont know how to write the expression. i was thinking a time related expression would help but im no good at expresions. please help.
    x = thisComp.layer("FaceValue").effect("SliderControl")("Slider")
    if (x == 1){
    400+34
    else if (x == 2){
    233.3+34;
    else if (x == 3){
    838.3+34;
    else if (x == 4){
    131.3+34;
    else if (x == 5){
    -299.7+34;
    else if (x == 6){
    -36.7+34;
    else if (x == 7){
    1011.3+34;
    else if (x == 8){
    -472.7+34;
    else if (x == 9){
    578.3+34;
    else if (x == 0){
    -124.7+34;
    else if (x == 10){
    -182;
    else if (x == 11){
    346;
    else if (x == 12){
    -639;
    else if (x == 13){
    90;
    else if (x == 14){
    -813;
    }else{
    wiggle(.2,10000);
    Filip Vandueren replied 16 years, 12 months ago 2 Members · 1 Reply
  • Filip Vandueren
    August 31, 2009 at 2:20 pm
    You’re just wiggling to get motion blur ?
    That’ll never work he way you want.
    The easiest way I can think of is to use the offset effect.
    place your layer so it’s centered behind your “window”.
    Apply the distort->offset effect.
    Change the y-value of the offset untill your first logo is in the right position it should be [layerwidth/2 , -slotheight] if that makes sense.
    Add two sliders to this layer named:
    visible slot
    (set this to 1)
    revolutions
    now apply this expression to the offset “shift center to”:
    numSlots=18;
    h=source.height;
    visibleSlot=effect("visible slot")("Slider");
    revolutions=effect("extra revolutions")("Slider");
    y=-(visibleSlot-1)*(h/numSlots)-(h*revolutions);
    value+[0,y]
    Okay, now you can just keyframe from visible slot 1 to visible slot 8 or whatever, and the right one should be in the window.
    next step: motion blur.
    Add a fast blur or box blur set to vertical only and add this expressino to blur amount:
    effect("Offset")("Shift Center To").speed/25*thisComp.shutterAngle/360;
    but we still need to add extra revolutions to sell the effect. Just keyframe the revolutions slider in whole numbers, every time you kayframe from 1 slot to the next.
    It can be done with an expression too, but that’s a bit more comples, and probably slower to render.
    Let me know if this makes sense to you.
