Activity › Forums › Apple Final Cut Pro Legacy › Easy Setup to 1080i 29.97 HQ shows 29.96
  • Easy Setup to 1080i 29.97 HQ shows 29.96
    Posted by Tpc Spider45 on April 15, 2017 at 1:08 am
    Im using the Easy Setup to capture to 1080i/29.97 Prores 422 HQ from an HDCAM SR. when I open the file in QT, the properties are showing the file is 29.96. Is there a setting some where that needs to change. Media info shows 29.97 and frame rate as constant. This is on a FCP version 7 using a Kona 3G card
    Shane Ross replied 9 years, 5 months ago 2 Members · 1 Reply
  • Shane Ross
    April 16, 2017 at 12:39 am
    Quicktime is wrong. Everything else is right. QT is wrong a lot when it comes to reporting frame rates.
    Shane
    Little Frog Post
