Activity Forums VEGAS Pro Easy question on Vegas project files
  • Easy question on Vegas project files
    Posted by Fabio Grammatico on June 27, 2011 at 1:53 pm
    Hi All,
    i have a shared pc where a bunch of people work using the same project. My question is:
    There’s a way to lock the permissions in the Vegas project file without interfering with the software itself ? I would like to makev it impossible to modify or delete.
    Rob Strobbe replied 15 years, 3 months ago 3 Members · 3 Replies
  • Danny Hays
    June 27, 2011 at 10:31 pm
    If you all have different login passwords, just move or save the project with media to your desktop or your documents. Other users don’t have access to those folders. Or just save with media to an external drive and keep the drive.
  • Fabio Grammatico
    June 28, 2011 at 7:04 am
    That’s not quite what i meant…
    when you create a project Vegas save it as .veg file.In this file there are settings that i don’t want to change.
    I want people to use the project but not alterate its content.
    any ideas?
  • Rob Strobbe
    June 29, 2011 at 6:49 pm
    Each event has a “lock” setting. Right-click one and go to Switches > Lock. To do more than one event, select them all at once and do the same. This doesn’t lock down the entire project — they can still add tracks, insert and edit other media, etc, but they can’t affect the existing ones. And, of course, it’s a simple matter for them to unlock events by reversing what you just did.
    Not much other than that within Vegas. You could use Windows itself to make the file read-only; then they could do all they want to the project, but wouldn’t be able to save the changes. And, again, they can reverse this assuming they’re not computer illiterate. 😉 Though more recent versions have better permission control, assuming these others aren’t using your Windows login or administrator accounts. Right-click the VEG in Windows Explorer, choose Properties, and go to the Security tab to alter permissions.
    Your last resort would be a third-part program to assign a password to files. I’m guessing some will let you specify a password for saving files but allow free access to open and use them.
    Rob
