Activity Forums Apple OS X Easy Question
  • Easy Question
    Posted by Chris Babbitt on November 11, 2009 at 8:19 pm
    Can I remove a hard drive from my MacPro, and then re-install it at a later date, and the computer will recognize it with the same name as before? Do I need to take any special precautions?
    Chris Babbitt replied 16 years, 10 months ago 2 Members · 2 Replies
  • David Hall
    November 11, 2009 at 11:44 pm
    Chris, As long as the drive isn’t physically damaged while its out of the system, it should come right back up when you reinstall it into the system. The only precaution I can think of would be if the drive you are removing is part of a RAID set. In that case you’ll have to make sure that the drives are placed back into the exact same bays as there were previously. If its just a stand alone drive though, you shouldn’t have any issues with removing it and replacing it at a later date.
    David Hall
    Service Manager
    Zero One Media Center
    Apple Certified Hardware Technician
  • Chris Babbitt
    November 12, 2009 at 12:15 am
    Great! Thank you David. What would I do without the Cow?
