Activity Forums Maxon Cinema 4D Easy Question
  • Easy Question
    Posted by Chris Holland on April 14, 2008 at 9:29 pm
    Hi ,
    Ok. I know this is a simple one but I can’t for the life of me figure it out.
    When I am making spline paths, for example a bezier path, as soon as I add a point I get the XYZ Axes for the point. Basically when this happens I can’t add another point in line with the Axis. Do I have to turn this off and if so how do I do it ? I am sure there is an easy way around this that I don’t have to turn this off every time but it is really annoying when I can’t figure something this simple out.
    Thanks.
    Chris Holland
    Editor/Animation/Design
    ChriHollandVideo.homestead.com
    Chris Holland replied 18 years, 5 months ago 3 Members · 3 Replies
  • Brian Jones
    April 15, 2008 at 2:06 am
    Side views – and you can swap from one view to the next while drawing a spline
  • Adam Trachtenberg
    April 15, 2008 at 4:37 pm
    You can also use the F12 hotkey to temporarily disable the axis.
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
  • Chris Holland
    April 15, 2008 at 6:02 pm
    Adam,
    Excellent. I thought there was like a one-touch way. Thanks.
    Chris Holland
