Activity Forums Apple Final Cut Pro Legacy Easy HDV Questions…I think
  • Easy HDV Questions…I think
    Posted by Jason Harvey on April 2, 2007 at 5:17 pm
    I am trying to not be scared of all the posts about everyones HDV problems…
    Here’s my latest question – hopefully its a quickie for you guys –
    -My tapes are HDV 1080i @ 29.97 —
    -My Camera is a SONY HDR-FX7
    At the moment I am VERY low on storage and CAN NOT afford to capture @ full 1080×1440 –
    I read that the Sony cameras have the ability to Downconvert while capturing…and then if needed I can go back later and Up-Res if needed.
    So – I’m you sure all know the Basics of my problem –
    **At DV NTSC – this capture is looking “SQUEEZED”
    **At DV NTSC ANAMORPHIC – I have letterbox.
    **What should I make my Capture and Sequence Settings?
    For now, delivery will most likely be a QT – for the web – Maybe a DVD…So…
    Can FCP compensate for this while capturing to make it 4:3? or do I need to do
    somethin’ else and convert it somehow?
    AND are there other settings I need to worry about like Interlacing and such?
    Thanks! –
    JHARVEY
    13 replied 19 years, 5 months ago 2 Members · 1 Reply
  • 13 Create COW Profile Image
    13
    April 2, 2007 at 5:33 pm
    HDV takes up just about the same space as DV douse so down-converting will not do much for you.
    Sense you are very low I sagest getting a new hard drive, drives are cheep and you want to keep 10-20% free on your hard drive anyway.
