Activity Forums Apple Final Cut Pro Legacy Easy FCP question?
  • Easy FCP question?
    Posted by Jeff Hess on January 28, 2009 at 7:53 am
    I recently discovered a project I’ve been working on has many audio clips with the pan set to -1 (whereas I want it at zero). Does anyone know if there is a way to select all audio clips in a sequence and set pan level via one command?
    Much appreciated if anyone can help.
    Cheers,
    jeff
    Tom Matthies replied 17 years, 7 months ago 3 Members · 3 Replies
  • Tom Wolsky
    January 28, 2009 at 10:33 am
    Select the clips and press Control-period.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Jeff Hess
    January 28, 2009 at 11:17 am
    Many Thanks Tom,
    You’ve saved me a sizable headache.
    -jeff
  • Tom Matthies
    January 28, 2009 at 2:21 pm
    Also…
    Select the clips>Modify>audio>Pan Center
    There are a number of other audio options under the Modify menu as well.
    Tom
