Activity › Forums › Adobe After Effects › Easy ease
  • Posted by James Hargreaves on June 22, 2005 at 6:32 pm
    Hi, is it possible to turn easy ease off. I,e got a complicated keyframe sequence going here but easy ease is doing funny things to the motion path.
    But I cant seem to deactivate it and when I delete a keframe and re-enter it’s settings the keframe reappears already easy eased.
    Any ideas?
    Many thanks,
    James Hargreaves
    Aharon Rabinowitz replied 21 years, 3 months ago 3 Members · 3 Replies
  • Matt Larson
    June 22, 2005 at 6:36 pm
    select the keyframe(s) and go to Animation> Keyframe Interpolation and change the Temporal and Spatial settings to linear.
  • James Hargreaves
    June 22, 2005 at 6:52 pm
    Thanx!
  • Aharon Rabinowitz
    June 22, 2005 at 8:49 pm
    I just want to point out that it’s unlikely they are easy ease frames – AE doesn’t make them out of the blue, even following other easy ease keyframes.
    Easy ease is simply a shortcut to making a keyframe that is continuous Bezier, with 0 velocity going in and out, and with 33.33% influence over the animation curve.
    What you are probably getting are continuous bezier keyframes, which look the same as the Easy Easy Keyframe. That’s because , as I said, Easy ease keyframes are really just continuous bezier keyframes, with very speciffic settings.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
