Activity Forums Adobe After Effects Easy Ease problems
  • Easy Ease problems
    Posted by Ramendemon on March 3, 2007 at 11:18 pm
    I just finished a comp with about 25 canera keyframes and thought I ‘d try out the Easy Ease keyframe function. I added them saved the project and quit After Effects. Later on when I opened the project I realized the Easy Ease made everything jerky. I am wondering if there is a way to turn the Easy Ease off?
    It’s better than a real job.
    Ramendemon replied 19 years, 6 months ago 3 Members · 3 Replies
  • Filip Vandueren
    March 4, 2007 at 2:56 am
    On the mac Command-clicking on keyframes toggles between bezier or linear interpolation,
    I guess that would be ctrl-click on PCs
    or you can go into the menu for keyframe-interpolation and choose ‘linear’ for temporal interpolation.
    I recommend adding a smoother (either the smoother keyframe assistant, or a smooth expression) to camera keyframes rather than easy easing.
  • Brian Charles
    March 4, 2007 at 4:13 pm
    If you only eased position on the camera and not point of interest it can make the animation appear jerky since the position and poi are not in sync.
  • Ramendemon
    March 5, 2007 at 3:41 pm
    Thank you so much, you just saved me so much time.
