Activity Forums Adobe After Effects easy ease PROBLEM with Linear/ease()
  • easy ease PROBLEM with Linear/ease()
    Posted by Bilal Alsurri on February 21, 2016 at 9:17 pm
    Hello,
    am trying to link some keys to markers using Dan Ebberts expression:
    L = thisLayer;
    if ((L.marker.numKeys > 1 ) && (numKeys > 3)){
    sIn = key(2).time - key(1).time;
    sOut = key(4).time - key(3).time;
    eIn = L.marker.key(1).time;
    eOut = L.marker.key(2).time;
    if (time < L.marker.key(2).time)
    linear(time,eIn-sIn,eIn,key(1).value,key(2).value)
    else
    linear(time,eOut,eOut+sOut,key(3).value,key(4).value);
    }else
    value;
    which in my project case i changed “L” to target a layer in the parent comp:
    L = comp("Comp 1").layer("Glass S01");
    Everything is working fine except for one thing, my ease animation!, i tried to replace the linear with ease, but this gave me the normal easy ease we do using F9, i want to preserve my ease animation i did in the graph editor! is there a way to control my In and Out animation with markers while preserving my ease curves?
    Bilal
    Bilal Alsurri replied 10 years, 6 months ago 2 Members · 2 Replies
  • Cassius Marques
    February 22, 2016 at 12:02 pm
    I believe the interpolation will then be controlled by the expression and not the influence of the keyframe itself. So, no.
    Cassius Marques
    http://www.zapfilmes.com
  • Bilal Alsurri
    February 22, 2016 at 12:32 pm
    Thanks a lot Cassius, but i still think that there is a workaround for it, i tried using valuAtTime instead of ease(t,tmim,tmax,v1,v2) and almost got there but this method shifts all the keyframes which miss the animation!
    I also found a way that controls time remapping keyframes with markers on the parent comp, but in my case and because i have video in the nested comp this will cause the video to be faster or slower!
