Activity Forums Adobe After Effects Easy Ease Glitch????
  • Easy Ease Glitch????
    Posted by Dan Callahan on November 14, 2013 at 8:06 pm
    Alright, working on some compositions of still images. I have been using easy ease to smooth keyframe motion.
    My problem is that even after I ctrl+click a keyframe to reset it, the easy ease motion is still applied even when the neighboring keyframe values are identical (think if both variables are set at 252; they will still fluctuate 4-6 points as if the easy ease is still applied.
    Does anyone have an explanation for why this occurs? So that I don’t have to completely scrap my layers and start over? I’m running CS 5.5; using .tiff files for the stills. I am precomping the image layer and adjusting the camera and precomp position variables to create the movement.
    Thank you kindly.
    Dan Callahan replied 12 years, 10 months ago 63,617 Members · 1 Reply
  • Dan Callahan
    November 15, 2013 at 5:57 pm
    Thanks Dave! Worked like a charm.
