Activity Forums Adobe After Effects Easing Multiple Effects Easily
  • Easing Multiple Effects Easily
    Posted by Max Jackson on September 11, 2008 at 8:03 pm
    Hi Cowfolk,
    I’ve taken a crash course in AE, and now like 2 years later, I’m ready to start applying what I learned.
    I’ve begun using the easing functions for AE effects. However, I find I can only move one at a time. When blurring, using mosaic, and scaling all at the same time, resetting the exact ease for each effect is a real pain considering the bezier tool is almost as fussy as the Flash pen tool.
    Does anybody know a quick way to select/change the easing of multipe effects at once?
    Any help would save me a lot of time tweeking bezier curves.
    -max
    Darby Edelen replied 18 years ago 2 Members · 2 Replies
  • Max Jackson
    September 11, 2008 at 9:48 pm
    Hi Dave,
    Thanks, that will be useful once I have them all set.
    Is there a way to select and change more than one at a time, or will I have to change them all, save as favorite and then just catalog what I want to do?
  • Darby Edelen
    September 12, 2008 at 4:46 pm
    [Max Jackson] “Does anybody know a quick way to select/change the easing of multipe effects at once?”
    So we’re talking about temporal interpolation here right? You’re using the graph editor in the timeline?
    You can select multiple properties at once to edit them in the graph editor together. Alternatively, if you want all of you keyframes to have the same influence and velocity you can select them, right click and go to “Keyframe Velocity…” This is far less visual than the graph editor though.
    Let me know if I’ve missed the mark completely on the question 🙂
    Darby Edelen
    NVIDIA
    Santa Clara, CA
