Activity Forums Adobe After Effects Expressions Easing and interpolation in text script problem
  • Easing and interpolation in text script problem
    Posted by Fabian Brugger on October 7, 2022 at 2:36 pm
    Hallo, i want to make a script that animates a text layer behind a mask kind of style and found some ae presets that i used for this. Now i want to put this into a script but when i animate the keyframes through my script the interpolation of the easing is different instead of it being horizontal (see graph screenshots) and so it bounces under the value of the 3rd keyframe.
    First image is the easing i want and what i would get if i just add easing though a plugin like motion and second image is what i get from my script.
    The script:
    //Easing
    var ease1 = new KeyframeEase(25, 25);
    var ease2 = new KeyframeEase(50, 50);
    var ease3 = new KeyframeEase(65, 50);
    //Undo Group to undow the action
    app.beginUndoGroup(“AnimateShapelayer”);
    //Code
    var comp = app.project.activeItem;
    var layers = comp.selectedLayers;
    for (var i = 0; i < layers.length; i++) {
    if (layers[i] instanceof TextLayer) {
    var textslider = layers[i].property(“Effects”).addProperty(“Slider Control”);
    var makeAnimator = layers[i].Text.Animators.addProperty(“ADBE Text Animator”);
    makeAnimator(“ADBE Text Selectors”).addProperty(“ADBE Text Selector”);
    var makeAnimatorProperty = makeAnimator(“ADBE Text Animator Properties”);
    makeAnimatorProperty.addProperty(“ADBE Text Position 3D”);
    layers[i].property(“ADBE Text Properties”).property(“ADBE Text Animators”).property(“ADBE Text Animator”).property(“ADBE Text Animator Properties”).property(“ADBE Text Position 3D”).expression = ‘sl=effect(“Slider Control”)(“Slider”); y_anim=thisLayer.sourceRectAtTime().height * sl/100*-1.4; x_anim=0; x=transform.anchorPoint[0]+x_anim; y=transform.anchorPoint[1]+y_anim; [x,y]’
    layers[i].property(“Masks”).addProperty(“Mask”);
    layers[i].property(“Masks”).property(1).property(“Mask Path”).expression = ‘const layerMidPoint = (outPoint – inPoint) / 2; const { height, width, top, left } = sourceRectAtTime(layerMidPoint); const topL = [0, -500]; const topR = [width, -500]; const bttmR = [width, height]; const bttmL = [0, height]; const pathPoint = [topL, topR, bttmR, bttmL]; const pathPointUpdated = []; pathPoint.forEach(item => pathPointUpdated.push(item + [left, top])); createPath(pathPointUpdated)’
    var sliderKeys = layers[i].property(“ADBE Effect Parade”).property(1).property(“ADBE Slider Control-0001”);
    sliderKeys.setValueAtTime(0, -100);
    sliderKeys.setValueAtTime(0.5, 10);
    sliderKeys.setValueAtTime(0.9, 0);
    sliderKeys.setTemporalEaseAtKey(2, [ease3]);
    sliderKeys.setTemporalEaseAtKey(3, [ease2]);
    app.endUndoGroup();
    Fabian Brugger replied 3 years, 11 months ago 1 Member · 1 Reply
  • Fabian Brugger
    October 10, 2022 at 10:00 am
    Ok i answered my own question, i understood the new KeyframeEase values wrong.
    I thought its 0 to 100 values for ease in and ease out but its units of the graph editor with the first value beeing units and the second beeing time?
    Can someone confirm this?
    Greetings
